92 accord stalls but pumping gas pedal revives
Old Apr 29, 2012 | 10:57 AM
mdg's Avatar
mdg
Default 92 accord stalls but pumping gas pedal revives
Hello, while driving the engine dies, tach jumps a couple times, and will stall out and quit unless you pump the gas pedal a few times and then it will pick up and sometimes run or you have to repeat and it will backfire.
most of the posts here refer to the ignition switch ( no problems while gigling key or pushing on the wires) or the igniter, it was replaced about 1k miles ago.
it has new plugs,plug wires,cap,roter,coil,igniter,fuel filter replaced 2x?
so was leaning twards the feul presure regulator?
Old Apr 29, 2012 | 12:32 PM
Clean the ground that is on the thermostat housing. Unbolt it and use either sand paper or a wire brush on the eyelet and bolt to make sure you have a good ground.
Old Apr 30, 2012 | 10:48 AM
mdg's Avatar
mdg
Default 92 honda dieing
OK forgot to mention.. the battery was coroded along with the main ground terminal... I cleaned up both and put in a new battery.... the problem is still there... A friend of mine came over and pointed out the cataletic converter, yea I forgot that one got me about 7 autos ago.. so thats my plan for today,
change out the exaust system..... we ran it just sitting holding your hand over the tail pipe not much psi... it died got it restarted hardly any psi... hope this also fixes the EGR problem its been unhooked to make it quit stumbling at a cruzing speed... i just plug the hose going to it and it runs great with the ck engine light on...
Old Jun 26, 2012 | 06:57 PM
Ryeguy's Avatar
Ever get this figured out?
Old Jun 27, 2012 | 08:01 AM
mdg's Avatar
mdg
Default 92 honda dies
well I changed out the exaust system $350....mufler fell apart and cat black can't see light through it..... still died, so did a tune up plugs, cap, rotor, timeing ....... had already cleaned the ground wires..... seems to be ok now and the EGR hose is hooked back up... I gave the car to my ex befor all this started and she hasen't complained any more... at least about the car
driftdoggy
May 23, 2013 11:16 PM
Hangfire79
Apr 4, 2013 07:07 AM
dcsmith
Mar 21, 2008 07:02 PM
SIXPAK GQ
Aug 31, 2007 10:05 PM
gypsyman
Jun 4, 2007 05:39 PM
