92 accord TCU replacement correct?
Old Apr 29, 2013 | 12:01 AM
Worck's Avatar
Default 92 accord TCU replacement correct?
I have a 92 accord Ex with AT. It was throwing a bunch of transmission control unit codes and the transmission was in limp mode. I took everyone's advice and replaced the tcu. Original pn was 28100-PX0-731-1M 3EX which I replaced with 28100-PX4-731 from ebay. The car shifts fine now and "seems" to be working. However, I cannot remember what the start up dash board light sequence is supposed to be so I am not sure if My repair was 100 percent successful/compatible. Upon turning key to on I see check engine, srs, and d4 light up solid and then go off after a few seconds. This leaves me with oil, battery, abs, and park light still lit. Once I start car only park light is left illuminated. I guess I never paid close attention. Let me know if this correct or if there is some error code here. FYI-- I jumpered the service connector after resetting tcu and cel light comes on solid that's it. No blinking D4 etc.
Thanks for any help or let me know if more info is needed.
Old Apr 29, 2013 | 06:48 PM
Sounds good to me. Each of those systems should do a "bulb" check when the key is first turned to "on/pos II". So they come on and go off....bulbs are good and systems are good to go.
Old Apr 30, 2013 | 12:56 AM
Worck's Avatar
thanks..I will keep driving for a few days and see what happens. However, I feel much better now and my car has a new lease on life after 270k.
93Accord2.2
Dec 20, 2011 06:27 PM
Mackie
Jul 15, 2011 07:40 AM
07Coupe
Jul 29, 2007 02:29 PM
thunder_x
Jul 27, 2007 09:59 PM
KEYZ
Apr 23, 2007 05:55 PM
