92 accord water pump
Old Jul 14, 2012 | 11:50 AM
fhorta's Avatar
Default 92 accord water pump
Hello all. My car leaks water when engine is running.and only.after it has reached a certain temperature.
I.checked hoses that are visible and none are leaking. Safe to say it's the water pump?? Thanks. I just want to make sure cuz I know It's a.hassle to replace pump.
Old Jul 14, 2012 | 12:14 PM
A cold pressurized leak test should disclose what is leaking. Water pumps leak from the drain on lower timing belt cover behind driver's wheel.
Old Jul 15, 2012 | 10:03 AM
fhorta's Avatar
Thanks. What im still wondering is wouldnt water start leaking from pump as soon as engine is started? My car doesnt leak right away, only after 10 to 15 min after engine has warmed up.
Old Jul 15, 2012 | 11:27 AM
You don't say whether it's leaking form driver or pax side.
A leak test is best solution unless you are willing to perform closer inspections than looking at ground.
Old Jul 16, 2012 | 12:45 PM
I've had a waterpump that leaked only after I shut off the engine. And then only if I had it running long enough to get fully warmed up.
Just as an illustration that it's POSSIBLE for the leak to behave in a strange manner.
scottdrag
Apr 6, 2008 10:13 AM
J2Performance
Jan 25, 2008 01:03 PM
J2Performance
Jan 15, 2008 12:46 PM
golman
Oct 22, 2006 10:53 PM
joe592
May 25, 2006 03:35 AM
