92 honda accord wont start
Old Jul 21, 2013 | 09:16 AM
Fuel is the next thing to check for. I'd crank it over a few times, then pull a spark plug and see if its wet.
Old Jul 21, 2013 | 10:04 AM
Honda717Pa's Avatar
yup there wet and smells like gas
Old Jul 21, 2013 | 10:27 AM
Well this is a weird one for sure. Did you take anything else off when you changed the radiator?
I suppose timing would be the next thing because if its getting fuel and spark it should run unless there is no compression or the timing is off.
Old Jul 21, 2013 | 10:41 AM
How many miles are on the maintenance items, like the distributor cap, distributor rotor, and the spark plugs?
Check for engine codes. See: https://www.hondaaccordforum.com/for...l-codes-35962/
Do you have a timing light?
Old Jul 21, 2013 | 11:04 AM
When you turn the ignition to ON, does the Check Engine Light turn on and then turn off?
Although you didn't change the thermostat, is the ECU ground cable connection clean and tight there?
Old Jul 21, 2013 | 11:06 AM
Honda717Pa's Avatar
distributor is brand new as well as cap and rotors spark plugs are about a month old i check it with timing light and the mark on the fly wheel is right where it needs to be but is jumping around
Old Jul 21, 2013 | 11:07 AM
  #17
Honda717Pa's Avatar
redbull-1 the check engine light is on it reads code 9
Old Jul 21, 2013 | 11:23 AM
  #18
Code 9 is for the CYP sensor in the dist.
Have a volt meter to do some testing?
Old Jul 21, 2013 | 11:31 AM
  #19
Attached are the troubleshooting procedures for Code 9.
Attached Thumbnails 92 honda accord wont start-code-9-troubleshooting.jpg   92 honda accord wont start-code-9-troubleshooting-continued.jpg
Old Jul 21, 2013 | 11:55 AM
  #20
Here is a pic. of the ECM 16-P connector wire harness referred to in the 2nd pic. above.
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
EPIFEMIO
Aug 25, 2007 03:32 AM
HustlinOwl
Sep 15, 2006 03:20 AM
