92 No Start
Old May 27, 2008 | 07:18 PM
wietgr's Avatar
Default 92 No Start
'92 LX 2.2L Auto
- Stalled while driving and will not restart. I checked for spark a each plug and there was no spark to any cylinder. I checked for spark at the wire from the coil to the distributor cap and found none. So im thinking that it may be the ignition coil... I just wanted to see if anyone had any other ideas before I go dropin $$$ ona newcoil. Thanks...
-Greg
Old May 27, 2008 | 07:42 PM
hondadude's Avatar
Default RE: 92 No Start
Be sure you have power at the coil Black/yellow wire with the key on.
That proves the voltage is going thru the ignition switch.
In the DIY section Desert Honda has posted a quick check that can be done with a test light to prove Coil or Ignitor
Tony1M
Nov 6, 2023 08:29 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
gasface11
Jul 11, 2012 12:33 PM
bpethomas
Jun 5, 2012 10:47 AM
brickballer
Apr 18, 2008 04:25 PM
