oil in the water
Old May 27, 2008 | 12:36 PM
pointer
Default oil in the water
a friend of mine has 2001 accord that has had the head gasket changed to fix oil in the water but that didn't fix it, still after 2 days of driving the radiator water is milky looking from oil. Does it sound like the block is cracked if the head gasket is good?
Old May 27, 2008 | 02:07 PM
lightshow's Avatar
Default RE: oil in the water
how well was the cooling system flushed out? could still be some residue. also could be a bad head gasket job.
Old May 27, 2008 | 02:35 PM
Did your friend take the cylinder head to a machine shop to get shaved to ensure that the matting surface is perfectly flat?
Old May 27, 2008 | 08:22 PM
pointer
He said he flushed the engine until the water was running clean, and I don't know about shaving the heads. This guy has built many dirt track race car engines so I figured he probably knew if the heads needed worked. He just has no experience on Honda's. I'll ask him tomorrow if theres any loss of power or any other symptons. I'll post more tomorrow.
MiyashiMeism
Sep 5, 2010 02:12 PM
mfilli01
May 11, 2010 08:34 AM
summerfish2001
Dec 4, 2008 02:25 PM
oma93
Dec 28, 2007 09:33 AM
Karthigan
Nov 27, 2006 02:55 PM
