2005 Accord EX Water in oil.....!
Old May 7, 2010 | 12:13 PM
mfilli01's Avatar
Default 2005 Accord EX Water in oil.....!
Shop said that the head was cracked. replaced head w/rebuilt one, replaced timing belt, water pump.
Got the car back, now there is water in the oil again...., ANY IDEAS?
Old May 7, 2010 | 03:58 PM
I would take the car back to the mechanic that did the work. Water + oil usually means a bad head-gasket. Was the rebuilt head milled so it was perfectly flat?
Maybe the coolant system wasn't flushed out, so it is residual oil? Another less likely possibility is a crack inside the engine block.
Old May 8, 2010 | 09:51 PM
I guess this is a V-6?? Both headgaskets checked?
Old May 11, 2010 | 08:01 AM
mfilli01's Avatar
Default CORRECTION - This is a 2001 Accord, 4 cylinder.
Old May 11, 2010 | 08:34 AM
OK, a 2005 4-cyl doesn't have a timing belt (has a chain) so that's where my V-6 comment came from...
Anyway, I guess I'd want to know how they ruled out a cracked block? A warped head would cause a new headgasket to leak, so was the "new" head milled flat? Top of the block not flat? Right now I can't think of other places for the oil & water to get together.
I imagine the shop should have done some work to rule out those things before spending your money on a head, so you could ask them about that.
A leaking waterpump would leak OUT (onto the ground) not into the oil. I hope it was all cleaned out thoroughly, so this isn't leftover oil from before the head-replacement.
Ineedhelp
Jul 20, 2022 08:44 AM
MiyashiMeism
Sep 5, 2010 02:12 PM
summerfish2001
Dec 4, 2008 02:25 PM
oma93
Dec 28, 2007 09:33 AM
Karthigan
Nov 27, 2006 02:55 PM
