Passenger window makes chirping without moving!
Old May 11, 2010 | 09:04 AM
ykattoum's Avatar
Default Passenger window makes chirping without moving!
Hi,
I have a 2003 Accord EX-L with 118k. The passenger's side door is making a chirping sound that is happening at a rate of about every 30-60 seconds. The sound seems like some sort of electrical noise, and it occurs when the car is on regardless if the car is moving or parked. It almost sounds like something from the window regulator/motor/switch is making the sound. The window also has an intermittent problem. It sometimes doesn't work when you are trying to put it up or down, or if does go down, it automatically goes back up. but then you wait for a little bit, and you can control it again. I almost suspect a problem from the switch, but if I am not touching either the master or door switch, why does that sound persist by itself. has anyone experienced this?
Thanks,
Michael Bomes
Sep 9, 2012 03:12 PM
pancho88
Mar 18, 2012 04:14 PM
tana_marie77
May 27, 2008 11:55 AM
Pogigreg
May 4, 2007 03:50 PM
RA1525
Mar 25, 2007 03:40 AM
