93 2.2 Help!!!
Old Oct 26, 2011 | 12:36 PM
93accordlowrider's Avatar
Default 93 2.2 Help!!!
i have a 93 honda accord 2.2 non vtec and i have a couple of problems. first off, the drive light "D" is flashing and now the car is running perfectly at an idle but when accelerating it is sputtering and skipping. i have changed the plugs, wires, and fuel filter and nothing has changed. if anyone can help i would be very appreciative. thanks.
Old Oct 26, 2011 | 05:19 PM
Moved to the proper section.
Suggest getting the codes ECU/TCU. See the Common DIY Threads for a write uo on jumoing the service connector amd then counting the flashes.
I see you did the wires and plugs, was the cap and rotor no due? When were they last changed/inspected.
Old Oct 30, 2011 | 06:11 PM
yeah i changed them when i put the motor in the car along with the water pump and the timing belt rotoray button and cap.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
