93 accord CRUISE CONTROL
Old Dec 23, 2007 | 10:05 PM
collierville's Avatar
Default 93 accord CRUISE CONTROL
I have a 93 accord 4-dr ex a/t.
The cruise control will not stay engaged. I dont think it is a break pedal problem. When the weather is hot the cruise will not work. Just today at 35 degrees the cruise worked for the first time in a long time.
I have read in a past post (Listed below) that "sir_nasty" had some trouble shooting for the cruise control system.
( alright I got the manual pages for your car.... full troubleshooting procedures/testing for the Cruise control... PM me your e-mail address or post it and I will e-mail it to you (it's in PDF format)
"sir_nasty" ---- Here is my email. can you send the trouble shooting tips. Kschumac@comcast.net
Old Dec 24, 2007 | 12:23 PM
hondadude's Avatar
Default RE: 93 accord CRUISE CONTROL
The description of temp sensitivity would lead me to suspect the slip ring under the steering wheel, here is the diagnostic chart;
http://img141.imageshack.us/my.php?i...rsetestzq9.gif
Old Dec 24, 2007 | 12:41 PM
sir_nasty's Avatar
hondadude is probably right but if you want the manual anyway just follow the link below and download it.
http://www.hondahookup.com/manuals/
Old Dec 24, 2007 | 01:47 PM
HONDADUDE & Sir_Nasty.
Thank you for the trouble shooting tree and link. Is there a way to fix or clean the slip ring if that is the problem. Or will I need a new one. Thank You.
Old Dec 24, 2007 | 02:57 PM
Hondadude,
On Step 5 pink wire , There is intermittent continuity ( 56 Ohms to 6-7k or More) when shift lever has pressure or is slightly bumped. leads me to belive there is a faulty shift position switch. can i clean this switch... steps 3 & 4 Check ok for horn........THx Ken
Old Dec 24, 2007 | 08:28 PM
hondadude's Avatar
Sure you can clean switch contacts, be sure the is no power to the circuit, and blast it out with brake clean and compressed air. If possible swipe a little conductive grease on the contacts.
DrBones
Jan 10, 2008 06:02 PM
aatc20
Sep 25, 2006 04:28 PM
alfredo123
Jul 24, 2006 01:09 AM
toka
Apr 1, 2006 06:12 AM
rabbit
May 3, 2005 01:28 AM
