93 accord lx wont start
Old Mar 7, 2012 | 09:45 AM
sweet_v's Avatar
Default 93 accord lx wont start
okay my 93 accord seems to not want to start most the time and when it does it hesitates to turn over....i have spark i have fuel but still no start ive change the batt alternator distributor plugs wires starter when i do get it started it runs and drives without a problem but it is not a constant start sumone pleze help
Old Mar 7, 2012 | 12:42 PM
Is the problem a failure of engine to be turned by the starter or engine turns over fine w/ starter but refuses to catch/run?
Be precise in the problem description and someone can help you.
Old Mar 7, 2012 | 01:42 PM
sweet_v's Avatar
the engine turns over fine it seems like the starters not catching its a new starter i thought maybe the flexplate but i was told that mine is fine its not missing any teeth and theres no cracks or anything it doent make any noiselike it would if it were loose my check ingine light is not on ive pretty much replaced evrything to do with the starting of the vehicle...starter alternator distributor pulgs wires battery waterpump timing belt
Old Mar 7, 2012 | 11:57 PM
It's still confusing the way you describe it. If it "turns over fine", that means the starter is doing it's job spinning the engine. Do you mean it doesn't fire?
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
