93 Accord Manual??
Have you got the cylinder out yet?
Rotate the plastic clip off the rod before trying to pull the rod out.
After the bolt (10mm socket) is removed, you may have to slightly twist the cylinder to remove it.
If you are going back to the locksmith with the trunk cylinder lock, ask the locksmith if the key code on the trunk cylinder is different than the glove box. I would have thought they should be the same.
Red Bull - I haven't gotten it off, it's hard to get at, and seems "stuck". Also want to know if that's going to make a difference - will there be a key code on there, one that will work????
Ugh - have to run some errands now, have an appointment at 1pm too - will check back here later.
Thanks all!!
Thanks all!!
, as do the other members as well.That pic/avatar is of my oldest son just after graduating from OCS - USMC. He was the pass in a car that was in an accident, he was killed just over a year ago. So having his picture there/here is my way of paying tribute/remembering him.
Tell your son-in-law "thank you" for his service from me/us.
Bragg is about an hour south of me, one of the other Mod's is stationed there now as well. Of course he doesn't get a chance to post much anymore but is on when he can.
I did send you an e-mail with the pic so between that and what Redbull posted you should be good to go on getting the trunk lock out. If not let us know and if you can post a pic of where you are stuck that will help.
Okay all you wonderful helpers/mods - I got the trunk lock cylinder out, it was just a little "stuck", but I got it out and managed to remove the rod without breaking anything so far!
I will bring the glove box cylinder AND the trunk cylinder in together - if they were the same, the key should open the trunk too, but it doesn't. I'm praying the code is found (I see something on there, is this a code? B3M2)
UPDATE: Trunk and Glove Box key codes ARE the same, but the trunk lock won't budge (possibly due to corrosion). Still no reason for the ignition not to work UNLESS it's been changed over the years??? If that is the case, what is my next step - Have a locksmith come to the car, or try to remove the cylinder?? #whatamess
