93 Accord Transmission stops working after 5 to 10 minutes
Old Feb 28, 2014 | 10:25 PM
Baztaz's Avatar
Default 93 Accord Transmission stops working after 5 to 10 minutes
I have a 93 Accord that has no flashing D4 or other codes. The car will travel just fine for about 5 to 10 minutes then it's like the transmission has gone into neutral. The motor is still running fine. I can pull over, turn the car off. Start it , shift into D4 and drive for a while before it does it again. I have changed the transmission fluid with Honda fluid, changed both solenoids and changed the TCM. With no success. Please somebody help me I'm at my wits end!
Old Mar 1, 2014 | 10:59 AM
Check the connectors to the solenoids to be sure they are clean, you replaced them so of course I'm talking about the other end.
Was the tcu re-built or used? If used I'd open it up and inspect it.
Old Mar 1, 2014 | 01:52 PM
Baztaz's Avatar
I'll check the connectors. I opened the computer and it looks good. I checked my old one and there doesn't seem to be anything wrong with it.
Old Mar 1, 2014 | 04:24 PM
Suggest checking for codes. Some codes don't set D3 light flashing.
Old Mar 1, 2014 | 05:42 PM
Baztaz's Avatar
I checked for codes. There were none.
Old Mar 1, 2014 | 06:19 PM
Symptom chart for "slips in all gears" suggests; oil pump worn/binding, pressure regulator stuck, or defective torque converter.
Since yours is intermittently OK, defective torque converter can probably be ruled out.
I believe remaining faults require trans removal to repair.
Old Mar 2, 2014 | 10:24 AM
2ToeRacing's Avatar
Even tho you changed the trans fluid,it sounds like the filter is getting clogged.Once you shut it off the trash in the trans falls to the bottom of the unit again. you start it up your able to drive again until the filter gets clogged again and stopping it from moving. Its ALWAYS best to replace the torque converter in a Honda rebuild
94_Accord
Jul 30, 2013 09:49 PM
erader00
May 28, 2012 10:42 PM
chez27
May 1, 2012 07:25 AM
BitBucket
May 29, 2011 04:07 PM
akeene
Feb 17, 2006 03:23 PM
