1980 Accord dies at 10 minutes, then OK after 2 minutes
Old May 29, 2011 | 01:58 AM
BitBucket's Avatar
Default 1980 Accord dies at 10 minutes, then OK after 2 minutes
Hi:
1. Starts instantly from cold (temperate Oakland, CA)
2. Dies at 10 minutes after McDonald's coffee drive-in, 1.5 miles or so
3. Backfire if crank to restart.
4. After waiting 2 minutes or so, starts OK, runs OK.
5. Repeatable in past few days. Has pooped out before from time to time. (This time I'm paying attention )
Do you think the car is complaining about having been ignored? Should I have gotten a coffee for the Honda too? Or is it some kind of electrical/igniter/coil problem?
Thank you in advance for your help.
-- Roy Zider
(Did check DIY section, and these forums and links to igniter diagnostics. Backfire indicates rich fuel exhaust, so probably not a fuel problem)
Old May 29, 2011 | 02:02 AM
deserthonda's Avatar
unplug the connector to TW sensor and try it ..
also make sure that float level in carb is ok ,, and that card is not running over ( sunk float ) ???
Old May 29, 2011 | 04:07 PM
BitBucket's Avatar
deserthonda:
Now that's something I wouldn't have thought of. I'll try your suggestion about the TW sensor and get back to you. Float sticking is a bit more inconvenient to test, but is possible. Car sits for days, then I drive it. Might take a few days to run these two down.
So you don't think it's the igniter, at least of first two guesses?
-- Roy Zider
aRousso
Aug 23, 2015 10:22 PM
Cthulhu
Aug 30, 2012 10:14 PM
Nicolai Hobbs
Jul 12, 2012 05:44 PM
Ice D
Jun 5, 2011 03:35 PM
HondaAccord93
Jul 18, 2010 03:37 PM
