93 accord vtech swap
swapping original f22a+auto with h22a+auto.. which came with ecu but wiring is a little different.. has anyone done this, is there a diagram that can be used, or another ecu/harness i should get?
That swap has been done a lot. I posted a link to an H22 swap guide in the DIY section a while back. Google search and searching this forum will help you to get organized.
I think that you will need the ECU from the prelude, because the stock 93 did not have vtec. You will want an ECU from a pre-96 prelude, so you can stay with OBD1.
I think the H22 swap is easier with the 4th gen (90-93) accords, because the honda mounts will work without modification.
I think the swap should be very similar to the 94 swap. I am not sure what parts you will need from the prelude for a/c, power steering, alternator, etc. There is a site called hondaswap.com that has a lot of info about this.
Google:
cb accord h22
or
cb accord h22 swap
The first few hits give some information. You'll just have to piece it all together. If you want to help the forum, keep track of what is needed.
Also found this site:
cb7tuner.com/vbb/showthread.php?s=&threadid=5423
cb accord h22
or
cb accord h22 swap
motor seller says: you cannot use a jdm engine wiring harness , you will have to use your usdm engine wiring harness no matter what engine you got in your car and use maybe ur injectors as well
which makes sense.. i'm gonna figure this out one way or another and let it be known! heh
