93 Accord Won't Shift out of 2nd gear
Old Jul 26, 2007 | 04:33 PM
hondadad69
Default 93 Accord Won't Shift out of 2nd gear
I have a 93 Accord with an auto tranny, and when I crank it, the park and drive indicator lights are both lit up most of the time. When this happens, the car will not shift above 2nd gear. On occasion, the drive light will NOT be lit up on startup. When this happens, the car shifts perfectly. Any ideas ?
Old Jul 26, 2007 | 04:37 PM
00AccordLX5spd's Avatar
Registered User
Default RE: 93 Accord Won't Shift out of 2nd gear
TCM/TCU maybe?
Old Jul 26, 2007 | 05:17 PM
finch13's Avatar
Yeah check the TCU connections. If you pull the passenger carpet back closest to the firewall you'll expose a metal panel. Remove the 4 10mm nuts and take the panel off. The ECU (big silver box) and the TCU (smaller gold box) are attached to the back of the panel. Double check all of the pins are in the connectors and the connectors are in tight.
letsclique
Jun 18, 2016 04:29 PM
94LxAccordCoupe
Nov 4, 2011 07:38 AM
pfrathjr
Feb 10, 2008 05:51 PM
HondaRacer4Vtec
Oct 14, 2007 09:00 AM
MAPULENTO
Feb 12, 2007 08:32 AM
