93 Accord won't start and MIL stays ON
Old Jan 10, 2009 | 11:34 PM
tryonline
Default 93 Accord won't start and MIL stays ON
I have a 93' Accord and have not been having any problems until the other day while driving the engine shut-off and would not start. After it sat for about 45 minutes it started and I drove home. It has not started since, it cranks and sounds like it will turn-over but does not start. In position II, i hear the fuel-pump for a few seconds then stop. The MIL (check) light stays on and does not go out. I removed the 'IN' fuel line from the fuel-filter and had my daughter crank the engine,a steady stream of fuel came out.(The weather is cold so the isses i've read about theMain Relay in hot temps should not be an issue.) Any ideas would be greatly appreciated, thanks.
Old Jan 11, 2009 | 06:58 PM
tryonline
Default RE: 93 Accord won't start and MIL stays ON
just pulled the spark plug wire from the first plug and tested for spark.....no spark! not sure what to check next?
Old Jan 16, 2009 | 06:47 PM
JTK's Avatar
JTK
I had a similar problem and it turned out to be the coil in the distirbutor. I would check that next then check the igniter. Also if you have oil in the distributor you can replace the seal inside. It is not hard to do and only costs about $15.00. Hope this helps
DIY Answers.
Mar 15, 2015 07:14 PM
WinstonDouble
Jan 21, 2015 11:53 AM
dg773
Nov 24, 2012 12:16 PM
tkrotchko
Mar 16, 2011 08:50 PM
jeffk14
Nov 21, 2008 01:55 PM
