93 Auto Fourth Gear Slippage
Old May 9, 2012 | 05:35 PM
muskokaman2's Avatar
Default 93 Auto Fourth Gear Slippage
Hi Guys...Any help would be appreciated...Car upshifts and downshifts perfectly. It's only in top gear (cruising on highway) that tranny randommly and mildly lurches, or momentarily hesitates or feels like it's slipping and then continues motoring just fine until the next time...Fluid has always been changed at proper times and has never dropped too low or changed color.
Any suggestions as to the cause and to why only in fourth gear?....Thanks.
PS. At times it appears it happens just when you accelerate ever so softly ..othertimes just while randommly cruising ??
Old May 9, 2012 | 08:29 PM
Is the tach reacting?
Check for any stored codes.
Next time this happens, note what rpm range the engine is running at.
Old Jun 5, 2012 | 05:39 PM
Poorman 212,
No the tach is not responding in any way.
I do not have an OBD1 reader. I can't check for codes unfortunately.
I have to apologize Poorman212. I have been both sick and did not have available internet access available to get back to you in a timely fashion.
Thanks you for your response. Not sure how to proceed as the problem still persists. Is it possible a fuel pressure regulator problem? that's just a far fetched guess actually?
Old Jun 5, 2012 | 05:57 PM
crispin's Avatar
you can check the codes using a paperclip.
Read the Sticky on the top of "general tech" it will show you how to do it.
Old Jun 6, 2012 | 06:30 PM
Please note the rpm range.....
Ryoku92
Sep 2, 2014 02:22 PM
AnthonypSmith
Apr 10, 2012 11:28 AM
Vancefish
May 2, 2008 09:48 AM
newwct
Sep 19, 2006 10:37 PM
