93 corner vent question. Easy answer?
Old Nov 23, 2007 | 12:48 PM
oma93's Avatar
Default 93 corner vent question. Easy answer?
Hi all,
New here. Just picked up a '93 accord LX. I noticed that no matter what position my heat or ac vents are in that the corner vents always blow air. I'd just like to know if this is normal before I tear the dash apart.
Thanks in advance!
Old Nov 23, 2007 | 09:27 PM
Planefreak's Avatar
Default RE: 93 corner vent question. Easy answer?
haven't heard of this issue before. My 86 allows air through the vents most of the time. Have you tried recirculating the air and shutting off the fan? That's what I normally do to stop the air.
Old Nov 28, 2007 | 01:34 AM
oma93's Avatar
Bump ... Can anyone else comment?
Old Nov 28, 2007 | 06:32 AM
Chiovnidca's Avatar
It's normal. you should be able to turn it off at the vent.
Old Nov 28, 2007 | 10:25 AM
00AccordLX5spd's Avatar
Registered User
Press the recirculate button on the AC controls and it should stop. All Hondas will blow a little air in if the AC is not set to recirculate.
Old Nov 28, 2007 | 11:10 AM
klrspz's Avatar
Most cars do that afaik...
At least every car I've ever been in.
Recirculate should stop it from doing that...
My old-*** VW Rabbit actually always blew COLD air through the corner vents, and only hot air through the center vents... by design...
Old Nov 28, 2007 | 11:15 AM
Registered User
old VW Rabbit = Pimp[sm=pimp.gif]
Old Nov 28, 2007 | 03:24 PM
oma93's Avatar
Thanks for the replies. The only reason i was wondering is that my 84 actually has a lever on each side below the vents for opening and closing completely, as well as the "close" on the vent it's self.
Great news, I don't have to tear the dash out
Shikaro
40
Oct 3, 2007 09:46 AM
morra1221
Mar 23, 2006 07:19 AM
eddieq19
Mar 15, 2006 11:49 PM
eddieq19
Mar 14, 2006 02:27 PM
Jan 15, 2005 06:14 PM
