93 Honda Accord EX quick question
Old Feb 9, 2010 | 04:54 PM
olopez's Avatar
Default 93 Honda Accord EX quick question
When I start my car it revs up higher than normal, I'm thinking it is taking in air from somewhere but everything seems to be where it should any suggestion on where I would inspect? Thanks for any help provided.
Old Feb 9, 2010 | 09:42 PM
Look in the DIY section for a thread about cleaning the "FITV". That's the fast-idle thermo valve which is supposed to give you a high idle rpm when you start the engine cold. If it's TOO high, maybe that thing needs to be cleaned or tightened.
Old Feb 10, 2010 | 07:13 PM
hondadude's Avatar
to add to the above advice; Be sure your coolant is full and the block burped thru the 12mm bleed screw at the T-stat housing.
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
get'er go'in
May 4, 2010 12:33 PM
ttwista
May 19, 2009 08:35 PM
iNSTiNKTx206
Feb 24, 2008 10:26 PM
Jeysin
Jan 25, 2008 05:46 PM
