93 honda will not start till i spray carb cleaner in the airfilter
Old Jul 30, 2012 | 12:20 PM
biggame's Avatar
Default 93 honda will not start till i spray carb cleaner in the airfilter
i have a 93 honda accord that will not start without spraying carb fluid in the airtake.then it runs till i turn it off an it cools down,an wont start? but when i do turn it off it will start when its hot ,but when it cools down it wont start till i spray more carb cleaner in it? what do i need to look at too fix this problem?ty john
Old Jul 30, 2012 | 08:15 PM
Check for codes first.
When trying to start "stone cold" does the cranking "sound" the same as when warm? Or does it seem a bit slower?
Old Jul 30, 2012 | 09:31 PM
Silver6gen's Avatar
that indicates a fuel issue. Either you are not getting pressure to the rail (fuel pump issue) or your injectors are not getting the electrical signal to inject.
Daily Cruiser
May 10, 2012 08:41 PM
tonymazarati
Mar 30, 2012 06:28 AM
Max Utility
Nov 22, 2010 01:01 PM
MrGmo
Jan 6, 2009 06:02 PM
