HELP engine runs till 3k rpm then spudders
Old Jan 4, 2009 | 04:01 PM
MrGmo's Avatar
Default HELP engine runs till 3k rpm then spudders
Hi Everyone my motor today started doing this weird thing... i turned it on and it usually doesnt struggle to turn on but today it cranked over a few more times than usual... then i started driving and when i was about to shift into second gear the motor spuddered then on second gear i watched the rpm gauge and i noticed that it wasnt going over 3k rpm it kinda reminded me of a speed or rpm governer because it revs then stops revs then stops but wont go past 3k rpm
can anyone help me figure out whats wrong with my car pls!!!!
thanks in advanced for your help.
Old Jan 4, 2009 | 07:42 PM
BlkCurrantKord's Avatar
Default RE: HELP engine runs till 3k rpm then spudders
Clogged cat
Old Jan 4, 2009 | 07:59 PM
Roadrash98vtec's Avatar
hmm maybe check intake and your exhaust? Could it be a clogged injector or fuel system?
Old Jan 5, 2009 | 12:36 PM
Get a check-engine light? If so, have it read atAutoZone or someplace like that.
If not, check whether the bulb is burned out for your check-engine light.
Old Jan 5, 2009 | 06:43 PM
MrGmo's Avatar
Thanks for all the replies everyone.
i dont have a cat.... i removed it months ago and put in a obx high flow cat... but i think its just a test pipe i could see straight through it.
i did get the check engine light a little after i installed the obx. but the car ran fine untill yesterday when i turned it on, i had let my little sister borrow the car and she drove it for a few months without problem... i checked the oil and it was DIRTY so i changed it last night and cleared the maintenance light.
reset the ECU and still no rev past the 3k... should i try a fuel injector cleaner?
Old Jan 5, 2009 | 08:01 PM
Are you getting a check engine light now?
Old Jan 6, 2009 | 02:16 PM
MrGmo's Avatar
yes its code P0335
would this cause the engine to not rev past 3k
Old Jan 6, 2009 | 02:29 PM
MrGmo's Avatar
crank position sensor.... thats what the code said... and it costs like 179 bucks!!!! ahhhhh.
lol but anyways i hope replacing this will solve my problem.... but its weird though it was working fine and then i start it up and run it normally and it screws up... thats just wrong to me.
also has anyone ever heard of the ecu going into "limp mode" ???
Old Jan 6, 2009 | 06:02 PM
MrGmo's Avatar
turns out some fkn animal bit the wires and it wasnt making contact... those fkn animals!!!!
purring like a kitten now
RAY101
Jun 18, 2012 11:14 AM
Daily Cruiser
May 10, 2012 08:41 PM
tonymazarati
Mar 30, 2012 06:28 AM
chris30721
Jan 6, 2011 08:06 AM
Accord Pete
Jan 31, 2010 02:50 PM
