98 honda starts runs then drops to 300 RPM after first rev.
Old Jun 4, 2012 | 06:00 PM
RAY101's Avatar
Default 98 honda starts runs then drops to 300 RPM after first rev.
no codes
new spark plugs
new wires
new value cover gasket
Old Jun 4, 2012 | 06:10 PM
crispin's Avatar
vacuum leak
Old Jun 4, 2012 | 06:38 PM
Low rpm means engine is starved for air; throttle plate is likely very dirty and idle air control valve ports and screen clogged. Clean both. See DIY forum for guidance.
Old Jun 4, 2012 | 08:54 PM
And in the DIY secton, look for a post by me about setting the BASE idle.
Old Jun 17, 2012 | 03:37 PM
RAY101's Avatar
you will love this I took off the battery post so not to run it down a few days later
i hooked it back up and the car runs great. what do you all think
Old Jun 17, 2012 | 06:35 PM
You're lucky or intermittent problem.
Old Jun 18, 2012 | 11:14 AM
RAY101's Avatar
Thank you for the info I am sure it will happen again until it troughs a code.
tdsilk
Jun 7, 2014 10:39 PM
mgharter
Mar 7, 2011 07:13 PM
chris30721
Jan 6, 2011 08:06 AM
irhunter
Apr 5, 2010 07:34 PM
Accord Pete
Jan 31, 2010 02:50 PM
