'94 Accord-1st gear
Old Oct 25, 2006 | 12:40 PM
abhijitgp's Avatar
Default '94 Accord-1st gear
Hi all,
I have 1994 Honda Accord EX, manual transmission. I did not use it for past one month as I was out of country. When I drove it last nite, it seems to work well, except it is a little tough to put it in 1st gear. Requires a bit more effort than usual. Any guesses why? Also, is there anything specific I am required to do in regards to maintenance such as getting an oil change or nything like that, since I did not use it at all for one month and the weather has changed now?
Thanks in advance
AG
Old Oct 25, 2006 | 04:31 PM
sir_nasty's Avatar
Default RE: '94 Accord-1st gear
the only thing to check as the weather gets cold is to make sure that the coolant is rated for that low of a temperature.... otherwise just standard maintence, oil change ever 3000 miles or 6 months etc....
Old Oct 25, 2006 | 04:32 PM
sir_nasty's Avatar
also on first gear it should ease up a little more with some use.... honda's are known for first gear being "finikey" at times.... when I come to a stop I usually push it down into second first then up into first...
Old Oct 25, 2006 | 07:05 PM
YeuEmMaiMai's Avatar
should go away within a couple of days.......
Old Oct 26, 2006 | 09:27 AM
Chiovnidca's Avatar
Have you checked the clutch fluid?
Old Oct 26, 2006 | 12:00 PM
abhijitgp's Avatar
How do u check clucth fluid?
Old Oct 26, 2006 | 01:09 PM
deserthonda's Avatar
i am thinking he meant the fluid in the clutch master cylinder,, to chk it just remove the cap and see how full the reservoir is,, if it is low , there is a leak in the system
if he meant tranny fluid, just remove the upper plug , 17 mm above the rt axle and oil should drip out.also make sure that there is NOT 90w gear oil in tranny , honda tranny take motor oil
Old Nov 7, 2006 | 03:45 PM
daddy's Avatar
Yeah...mine has done this since I have owned my Honda (94 Accord LX)...First gear just gives me headaches. Sometimes hitting second before first makes it glide in a little more smoothley, but it is really embarrassing when I am sitting in neutral at a stop, and the light changes, and there I am fishing for first!!! LOL There has to be a way to make this go away! Otherwise my car runs fine.
peace out,
daddy
letsclique
Jun 18, 2016 04:29 PM
SirJohnIII
Dec 12, 2012 03:30 PM
onealr
Oct 10, 2010 09:52 AM
5ofspades
Jul 25, 2009 05:26 AM
EHondaWins
May 19, 2007 07:43 PM
