94 Accord 2.2 does not crank
Old Mar 7, 2017 | 11:05 PM
Kevin.pope's Avatar
Default 94 Accord 2.2 does not crank
My son-in-law was driving the car down the interstate and the car just died.
When turning the key on, I get all accessory features, but engine WILL NOT CRANK. You can hear the starter bendix engage, but that is it.
Please help!!!!
Old Mar 8, 2017 | 12:34 AM
The Toecutter's Avatar
Please help!!!!
Sounds like starter rebuild or replace time to me. If the starter bendix is kicking out, then the starter itself isn't turning. The bendix should kick out, and the starter should both spin at the same time. Since this isn't happening, this means the starter is due for a commutator cleaning and new brushes.
Old Mar 8, 2017 | 06:20 PM
Kevin.pope's Avatar
But the starter crapping out would not cause the engine to die going down the road would it? Sorry if I'm being ignorant
Old Mar 8, 2017 | 07:44 PM
You are right. The engine cutting out while driving has nothing to do with the starter.
Sounds like the electrical to the starter is working, since the bendix engages.
I'd probably remove all the spark plugs and try cranking the engine by hand using a 19mm socket on the crank pulley bolt. There is an access hole in the plastic in the front driver's wheel well. Turn the engine by hand in the direction the tires move in drive (counterclockwise when looking at the front driver's tire). See if the engine moves smoothly when cranking by hand.
Robert Pemrich
May 15, 2014 05:23 AM
Melissa Mcdowell
Apr 20, 2014 08:45 AM
Thrawbrob
May 6, 2013 06:04 AM
fading
Oct 15, 2012 09:20 PM
niknik57
Apr 16, 2012 10:47 PM
