94 accord 4 cyl vtec no compression
Old Jan 10, 2006 | 02:56 AM
nman
Default 94 accord 4 cyl vtec no compression
Any ideas what could it be? there is no commpression in any cylender
Old Jan 10, 2006 | 04:03 AM
pepecrower
Default RE: 94 accord 4 cyl vtec no compression
Nman need more information, No cmpression can be several different things. What happened last what problems are you having? Any water in oil? White smoke in exhaust??
Old Jan 10, 2006 | 05:44 AM
lightshow's Avatar
yep definately need more info, im also thinking i have never seen an instance where there wasnt any compression in any cylinder. in my book thats just called a good run. im hoping you just left it wide down the freeway for a good long while. well on to some help, check the timing belt first, pull the valvle cover and then take the top timing cover off to check it. thinking about it, if you absolutely just lifted the head right off the block you would see this happen, and if you have let it run hot a few times this may be a possibility and if it is its just a fun job to fix it, and if you lifted a head you should be proud. just pull the head, tow the car over to your local (reliable) machinist and have him helicoil every one of the holes, get a new head gasket and bolt that bitch back on, if the guy does it right youll be good as new. like was said before though, we need more information, especially what exactly happened immediately before this problem occured. good luck
lightshow
Old Jan 10, 2006 | 12:47 PM
6thgen's Avatar
Could be seals, rings, etc.
Old Jan 11, 2006 | 11:52 AM
deserthonda's Avatar
zero compression ? or very little?? did car die and you have tried restarting it for a long period of time??? it could be cylinder wash,,,,,,,,,,,remove plugs, put some ATF fluid in each plug hole and retry..
Honda Accord Tuner
Feb 2, 2010 08:41 AM
sinister1
Dec 9, 2007 08:22 PM
dcsmith
Aug 19, 2007 08:19 AM
ths1973
May 20, 2007 11:21 PM
mrmatrix
Aug 12, 2006 05:39 PM
