94 Accord AC refrigerant leak
Old Apr 3, 2012 | 06:33 PM
this is what I had in mind. Cut/paste the url into your browser.
"http://www.harborfreight.com/25-cfm-vacuum-pump-98076.html
The venture pump is the vacuum level will not remove moisture as well, but venturi pump is better than nothing.
Suggest removing and inspecting evaporator. This is likely source of leak.
Also check compressor. If there's a large dirty oil/dirt ring around compressor clutch rotation plane, the compressor shaft seal is leaking. Shaft seal can be replaced or compressor replaced.
ak474u
May 4, 2015 11:15 PM
JimboC
Jun 14, 2012 04:23 PM
dunnskii
Jan 30, 2011 09:34 AM
bjr001
Dec 1, 2010 06:44 PM
reeling
Aug 27, 2008 10:53 AM
