94 accord d4 tcm code
Old Jul 22, 2011 | 04:30 PM
I think that the brake lamp turns when there a difference between resistance between the bulbs is detected by a sensor on the driver's side tail light. You should download that shop manual and clean the appropriate grounds. G551 and G501. Those are in the trunk. The shop manual will show those locations.
You may want to remove the brake bulbs and make sure there is no corrosion on the connectors or that the bulbs are not loose.
Old Jul 22, 2011 | 04:42 PM
Originally Posted by mikekjr26
its not i just looked at it and cleaned it. not sure of the results might be bad. thanks for your help
If you download the manual PAH referred to, you can get specs on the sensor and check sensor resistance is in spec. If it measures open or dead short, it's bad.
rickthefix
Jun 13, 2014 06:25 AM
brockj
Jul 25, 2013 11:31 AM
brockj
Jul 25, 2013 10:06 AM
jethro
Nov 11, 2011 03:31 PM
appleman
Sep 27, 2007 11:44 AM
