94 accord doesnt like starting
hey everyone i have a 94 accord lx 5sp 2.2l. a couple months ago my car shut off on me and wouldnt start so i took it to the shop and they said it was the computer, so i replaced it. i got a used one from shipecm.com. then my mom was driving it earlier this week and i cut off and wouldnt start for her. i pushed it to my house. couple days later i tried to start it and it started then shut off 5 minutes later and wouldnt start back up. i was told it was the fuel relay switch so i replaced it and sure enough it wont start. please help thanks
Are the maintenance items up to date like the distributor cap, distributor rotor, and the spark plugs?
When the car is not starting, you need to determine if the problem is due to lack of spark or lack of fuel. Do you have a timing light? That is the quickest way to verify spark.
Does the check engine light turn on while driving? In the common diy thread on top of the gen tech help forum, there is a link to checking engine codes. Check for any engine codes.
After you check for codes, disconnect the battery and clean all ends of both battery cables with a small wire brush or some sand paper.
The NGK plugs recommended for your car come at the proper gap setting. Those plugs are the V-power copper plugs ZFR5F-11 that you can get at most parts stores.
If you look at the All members must read before posting, there is a tegger.com link that shows how to pull a spark plug wire and test for spark.
Do you have a volt meter?
Also, when the car will start up, can you get the car to stall out by shaking the key?
I would still check for codes just to be thorough. It is pretty simple to do.
If Check Engine Light (CEL) is on, get these codes (Check DIY forum for OBD1 procedure) and post them.
First step w/ no-start is to understand whether fuel or ignition is source of the problem, no matter what you might think is the problem.
These checks must be done when No-start condition exists. It will do no good to check when car is starting.
1) Turn keyswitch to On. Does the CEL, Alt, and Oil light come on immediately. CEL should go off after 2-3 secs.
2) When keyswitch is turned Off to On, you should also hear a soft click from under the dash and fuel pump in fuel tank come on and run for 2-3 secs. Fuel pump will stop and CEL will go off at same time.
If above 2) checks show all lights are coming on correctly, and you hear the fuel pump run/cut-off, then fuel delivery is likely and ignition fault is likely.
If you're missing the Alt, Oil, and CEL coming on, then ignition switch assembly is likely faulty. Easy diy replacement. See DIY forum.
If ignition is indicated, suggest going to techautorepairs.com/ignition.html for guidance on diagnosing where igntion is failing.
CEL should come on when keyswitch is first turned to On and go off after 2-3 secs at same time fuel pump goes off. If you're not getting this combination, you may have an ECU problem.
Check fuses 8 and 9 in under-dash fuse box. Some inconsistencies in manual, but one of those supplies power to the CEL. Replace if bad.
Suggest pulling BackUp Fuse (under hood fuse box, Fuse 39, Inside/Rear row of fuse box) for 20 secs to reset the ECU. If still no CEL, and fuses are good, the ECU is likely faulty.
Check ebay and car-part.com for a used exact replacement for your year/trim accord.
... or a burned-out bulb for the CEL.
hk15
Jul 5, 2011 06:38 PM
