94 LX is starting to sound like a go-kart
Old Jul 23, 2013 | 11:47 PM
skyfire322's Avatar
Default 94 LX is starting to sound like a go-kart
This past weekend, I've done some engine "work". Pretty much just cleaned the throttle body with some cleaner. When backing out of the driveway, I did over a bit of curb, but checked underneath just to make sure nothing came loose and everything looked fine.
I do know I have an exhaust leak somewhere, and the EGR ports are clogged, which I plan on cleaning on Sunday. By power of deduction, I have a feeling it's probably the exhaust.
Every time I accelerate, it sounds like a go-kart (very obnoxious puttering noise). Though quite funny, it's a little annoying.
Ideas?
Old Jul 24, 2013 | 06:07 AM
Pinpoint the location of the exhaust sound.
- Park the car leave the engine idling.
- Hold a wadded-up rag against the tailpipe, not enought to stall the engine.
- The higher back-pressure will make the exhaust leak louder & easier to find.
Old Jul 25, 2013 | 11:25 AM
skyfire322's Avatar
It sounds like it's coming from the front half of the car. It is quite loose in the back too, so it looks like this will be a weekend project! Thanks, Jim!
Old Jul 25, 2013 | 01:12 PM
hondafreak91c's Avatar
Check around the exhaust manifold area. If you went over a curb, you could have cracked the manifold, or any of the piping before the cat.
Old Jul 25, 2013 | 02:19 PM
It's a 2-person job. Hold the rag while your helper looks & listens up front.
Old Jul 27, 2013 | 08:31 AM
skyfire322's Avatar
Not sure if this is any help at all but while I was driving to work yesterday, a little bit of white smoke for a short bit (not more than a minute) shot out the back. First time it has happened since going over the bump... I know that usually means a head gasket/coolant leak, so I'll be checking color/level of coolant tomorrow.
SandMan
Sep 22, 2007 12:33 AM
MrGmo
Sep 20, 2007 08:49 PM
JKennedy1612
Jul 30, 2007 08:55 PM
ouchevelles
May 7, 2007 03:42 AM
solobaric6800w
Jan 10, 2007 08:43 AM
