94 Accord DX timing belt replacement
Old Mar 26, 2008 | 10:24 AM
insadj05's Avatar
Default 94 Accord DX timing belt replacement
This is a general questiong about timing belt replacement. I have a 94 Accord with 200,000 miles on it. It ran well before my daughter decided not to have the timing belt replaced. She was at a stop sign and just taking off when it broke. My question is, is this worth replacing the timing belt and replacing possible bent valves? Is there more to it if a valve is bent? Or should I just try to sell it for parts. It has a new a/c compressor, radiator, tires, o2 sensor, brakes. Windshield was replaced a year ago. Except for the usual Honda rust by the back tires the paint is in pretty good shape. I do most of the work in it except for the A/C. Just never tackled the valve train.
Thanks for your Honest reply's.
Old Mar 26, 2008 | 10:32 AM
brayner's Avatar
Default RE: 94 Accord DX timing belt replacement
from personal experience, because the car was stopped it's possible the damage was very mnimal. I think it would be worth putting a new belt on it. It would be best to inspect the valves and pistons, I don't know if you can do this without removing the cylinder head. Perhaps an actual mechanic can chime in here.
Old Mar 26, 2008 | 11:52 AM
I had timing belt become mistimed (not due to breakage) from camshaft on my 97 Acura 2.5TL (similar engine to Accord 2.2L 4 cylinder). The engine stopped dead while driving due to a mechanic's error on the car (harmonic balancer bolt was not correctly tightened) while my son was away from home. I retrieved the car and re-installed timing belt and reset valve timing. Engine started but missed badly.
I had a borescope inspection performed by a local garage. This introduces a fiber optic scope into each cylinder to look at the valves and pistons. Damage to a piston would require engine removal repair or replacement. In my case only the valves were damaged. Cylinder head was pulled, valves replaced (5 bent), and new head gasket installed. Car is now running fine. Borescope is a good thing to avoid pulling head to find pistons damaged.
Old Apr 2, 2008 | 10:28 AM
insadj05's Avatar
Thanks, for your responses. I will give that a try.
mark95
Jan 22, 2015 09:34 PM
mark95
May 18, 2009 11:47 AM
Tony1M
Apr 1, 2007 05:42 PM
srt
Sep 27, 2006 02:17 AM
