94 Accord engine problem
Old Jul 30, 2007 | 10:40 PM
toddyfresh's Avatar
Default 94 Accord engine problem
I posted this before but I got some new info. My car blows out white smoke and smells like antifreeze sometimes. IfI wanna start itI have to dry the plugs out which are usually covered in water. Once started the radiator will loose water and the cooling system will be heavily pressurized. It will even get pressurized heavily if i try to start it and it doesnt start.
Old Jul 31, 2007 | 01:08 AM
f22turbo
Default RE: 94 Accord engine problem
Well first thing you need to do is a compression check, when it fails the compression check let it slowly sink in that you have either a blown head gasket, a cracked/warped head or worse a cracked or warped block. The only way to tell for sure is to tear into the top end. Sry it happens to the best of us.
trouble
Aug 21, 2012 07:46 PM
kellysa111
May 1, 2009 08:35 AM
StatzFinest
Feb 10, 2008 11:32 AM
hopkinted
Dec 30, 2006 04:41 PM
ferry
Jun 13, 2006 10:09 AM
