94 Accord Ex Weird Noise
Old Jan 21, 2011 | 11:52 AM
d7hawks's Avatar
Default 94 Accord Ex Weird Noise
i ran into a curb going around an icy turn, my front drivers side tire smashed into the curb and messed up my car. i had to replace the outside tie rod and the sway bar link, i still have a pulsing vibration coming from the front end. i looked at other peoples ideas and some people said it might be a ball bearing. does anyone have any ideas?? please help, thanks
Old Jan 21, 2011 | 12:15 PM
Have you ruled out a bent wheel? Damaged belts in the tire?
Old Jan 21, 2011 | 12:20 PM
d7hawks's Avatar
yeah i changed to my summer wheels and it still made the same noise, ive been told it could also be the inner tie rod? but i wouldnt think it would make a pulsing vibration noise
Old Jan 21, 2011 | 12:33 PM
Check for loose balljoints.
- upper control arm
- lower control arm
- outer tie-rod end
- inner tie-rod (that balljont is inside the rubber rack boot)
Any of them would allow the wheel to wobble while driving.
Lift the front of the car & spin the wheel. Bent hub causing the wheel to wobble?
Old Jan 21, 2011 | 12:39 PM
d7hawks's Avatar
its not a bent hub cap, the uppar control arm and ball joint have a tiny bit of play and im going to replace that next pay day but i didnt figure it could cause a noise that severe.
Old Jan 21, 2011 | 02:28 PM
There's a radius rod bolted to the lower control arm. That radius rod goes forward where it's bolted into the car's structure with rubber bushings. Easy to overlook cause it just dissappears forwards towards the front bumper. The curb hit might have loosened that at the forward end???
(just another thing to check & rule out)
Seems like you'd need more than a "tiny bit" of play to cause your problem, but ????
Old Jan 21, 2011 | 04:41 PM
d7hawks's Avatar
okay i will check that out, thanks for your help. hopefully i can get this problem fixed soon
stockxplorer
Sep 25, 2022 04:15 PM
straydog216
Aug 15, 2014 09:36 PM
jalospride
Dec 11, 2010 06:59 AM
TheCelt16
Mar 26, 2009 05:21 PM
