94 accord lots of goodys runs like crap
Old Mar 26, 2012 | 11:43 PM
chonisready's Avatar
Angry 94 accord lots of goodys runs like crap
Wat up peeps im new to this forum in need of help, I have a 94' accord f22b1 5 speed, here's the problem, I recently put a 68mm jdm throttle body and pro1 headers and a p28 ecu w/hondata s300 now the car wont idle right it jumps from 1000rpm to 2000rpm and it runs very bad. So far I replaced the tps and map sensor and I check for any vacuum leaks, none found. I really dont know wat to do to fix this problem. Any help would be useful, by the way I already had adjustable-cam gear, cold air intake, test pipe and straight pipe from cat back w n1/muffler.
Old Mar 27, 2012 | 12:15 AM
Did your P28 ECU come out of a manual or automatic accord? Search the web to be sure the pinout for the P28 is the same as for the ECU for the 94 accord. I think the accord is a P0A ECU.
Did the check engine light turn on and have you checked for engine codes?
Old Mar 27, 2012 | 06:51 AM
Are you sure the tune is good?
Checked for vacuum leaks around the throttle body?
choffman41
Jan 28, 2013 05:10 PM
scjfly
Jun 28, 2011 06:14 PM
odatdamkidagain
Nov 3, 2009 03:51 PM
