94 Accord LX Coupe Going Dim Inside
Old Jan 23, 2013 | 05:35 PM
wannakeepmy94Accord's Avatar
Default 94 Accord LX Coupe Going Dim Inside
1994 Honda Accord LX Coupe 177,000 miles
Does the 94 Accord have an interior dash light cluster like the later model years, or will I have to replace separate bulbs? Slowly but surely, the bulbs are either burning out, or the fuses are failing. I have no light in shift console, intermittent light behind AC/Heater, and the tach lights are getting increasingly dimmer with time.
Thanks,
Jonny Mo
Last edited by wannakeepmy94Accord; Jan 24, 2013 at 12:47 PM. Reason: Apparently there was not enough info. because there were no responses
Old Jan 24, 2013 | 11:53 PM
go-part's Avatar
Former Sponsor
Check the dimmer switch, it could be bad/dying
Old Jan 25, 2013 | 12:33 AM
94ex915's Avatar
Almost A Senior Member
Thanks,
Jonny Mo
Ya check your dimmer switch on the left side of the steering wheel. Also test your alternator with a volt meter.
Old Jan 26, 2013 | 10:10 AM
There are a number of bulbs that can go bad.
Old Jan 26, 2013 | 11:00 AM
Roader's Avatar
X2 on burned out bulbs. The bulbs in what Honda calls the "Illumination Assembly", #17 in the pic, light the tach, speedometer and fuel/temp gauges from above. Two bulbs in that assembly are available at any auto parts store. Since the consoles have to come out to replace those bulbs, may as well check/replace any bulbs in the shifter and HVAC while it's apart. The HVAC bulbs are strange. Radio Shack carries one that will work, PN 272-1092.
Attached Thumbnails 94 Accord LX Coupe Going Dim Inside-b__1210.jpg   94 Accord LX Coupe Going Dim Inside-prs1c-2266427w345.jpg
Old Jan 29, 2013 | 08:23 AM
Thank you so much Roader! That diagram is exactly what I needed!
Jonny Mo
fahad
Dec 31, 2013 07:47 AM
bigridge83
Apr 25, 2011 06:53 PM
markinchico43
Jan 20, 2008 08:34 PM
NoMoreVWs
Nov 25, 2007 09:04 PM
72mustang
Feb 12, 2006 10:16 PM
