94 Accord LX Dash Lights Flickering on and Off
Old Oct 22, 2011 | 11:40 PM
nismoawan's Avatar
Default 94 Accord LX Dash Lights Flickering on and Off
My 1994 honda accord dash lights started flickering on and off the other day. I would naturally assume this is a fuse, but if a fuse is blown they wouldnt work at all. Anyone else have this problem and what it could be? It's fine except for driving at night its kinda spooky.
Old Oct 23, 2011 | 08:32 AM
Has any recent work been done to the car-radio, pull the cluster, ect?
Also when you say dash lights, is it all of the small lights or just the cluster.
Old Oct 23, 2011 | 09:19 AM
wunderbra's Avatar
Check the dimmer switch on the left side of the dash panel. Right next to the cruise control master switch. It is probably the cause. Had the same problem on my 94 EX. It has a little knurled rheostat **** that pops out and turns to adjust the brightness. It is an easy repair. I got one from salvage. Just pull that little square switch straight out, disconnect from the plug and install the new one in reverse order.
Old Oct 23, 2011 | 10:25 PM
nismoawan's Avatar
yea I actually just installed a new radio. that was a couple months ago and it was a non issue until a week ago...the dimmer switch could also be a possibility but it was working fine a couple weeks ago as well
BPRescue
Nov 8, 2013 09:09 PM
chintan007
May 22, 2011 06:20 PM
repairmanjack81
Apr 17, 2010 07:26 PM
PAhonda
Mar 30, 2010 11:21 PM
Brian
Feb 2, 2006 08:04 PM
