94 accord lx idles up and down?!
Old Nov 14, 2007 | 01:17 PM
Jahsaccordcoupe's Avatar
Default 94 accord lx idles up and down?!
I have a 94 honda accord lx and I have replaced every sensor from TPS,IAC,MAP and the little white tipped sensor on the back drivers side of the manifold and the car still idles up and down between 1 and 3 grand even after warming up ...what else is there that could be causing this problem.....Also around 4 grand it seems to be loosing power will not pull as hard as when it first starts off...any Idea what that could be?
Old Nov 14, 2007 | 01:25 PM
rsanchez
Default RE: 94 accord lx idles up and down?!
You could be low on coolant, could also have air in the system.
Old Nov 14, 2007 | 01:27 PM
I also checked the coolant and replaced the cap...
Old Nov 14, 2007 | 02:39 PM
rsanchez
http://www.cb7tuner.com/vbb/showthread.php?t=53161&highlight=idle
Check out this link, it helped me with idle problems. If you read the whole thing, there are instructions on bleeding your coolant system (it worked well for me).
Old Nov 15, 2007 | 04:51 PM
deserthonda's Avatar
https://www.hondaaccordforum.com/SUR...m_46125/tm.htm
take a look at this as well..
Old Nov 16, 2007 | 06:04 PM
Hey everyone...thank you all that gave me useful info in trying to figure out my surging idle problem....on 94-97 models if you ever run across this problem pull off your throttle body and under that is a plate with 2 phillips screws pull that off and most likely the white peice with 2 slots on the sides worked itself loose creating a vaccum leak which causes the car 2 idle up and down the whole process takes about 10 mins
TnAsTy420
Feb 19, 2012 06:05 PM
ex man
Feb 10, 2012 12:04 AM
JTOKA
Jan 9, 2012 07:01 PM
spsweet
Feb 26, 2010 02:34 AM
achilles600
Jun 18, 2009 10:13 AM
