94 Accord LX: Surging idle
Old Dec 2, 2011 | 08:59 PM
Wiley-X's Avatar
Default 94 Accord LX: Surging idle
A couple of years back I had a problem with the idle. It would surge between 1,000 and 1,500 RPM. Vroom. Vroom.
I changed the plugs, distributor cap, and rotor and the problem vanished.
Almost two years to the day, the problem is back again. Vroom! Vroom!
I'm pretty sure that the plugs and distributor cap haven't gone bad in 25,000 miles considering the last ones were in for 70,000.
Any ideas?
Of course the weather is perfect for working on cars outside. :-(
Old Dec 2, 2011 | 09:25 PM
Low coolant or a dirty IACV would be where I would start.
If coolant, where did it go, be sure to bleed the air out.
Old Dec 2, 2011 | 09:46 PM
UhOh's Avatar
my '93 does that in spades during warm up only though.
1700 - 2300 rpms, lasts about a minute.
look forward to analysis and your solution.
Old Dec 3, 2011 | 06:52 AM
joec44's Avatar
poorman is spot on dirty IACV most times can be cleaned on car
Old Dec 3, 2011 | 01:25 PM
Also look in the DIY section for a post by me about setting the BASE idle. Honda idle-control system is kinda touchy about how it's adjusted.
Old Dec 11, 2011 | 03:47 PM
Wiley-X's Avatar
Had a chance today to go and see what the coolant is like. Radiator is full to the brim. Opened the bleed valve and coolant came right out.
I guess now I need to look at how to clean the idle control valve.
Old Dec 12, 2011 | 06:34 PM
In the "Common DIY Threads" sticky at the top of this section is a "how to" clean the IAC, might as well inspect the FITV and then follow Jim's "Base idle" write up.
Old Dec 12, 2011 | 10:35 PM
anthonylark's Avatar
just hapend on mine there are lines that are vacumized check all vacum lines for leaks
amcdonal86
May 8, 2011 05:27 PM
Honda hobby
Sep 15, 2009 10:28 AM
wjt
Jul 2, 2007 01:15 PM
wanderer63
Nov 23, 2005 01:17 AM
kwiggers
Mar 16, 2005 07:29 PM
