94 accord needs a front license plate
Old Jun 18, 2015 | 02:03 AM
fixinmyself's Avatar
Default 94 accord needs a front license plate
Hello, this is my first post here, my attempts to find information at another forum went sorta without fruit so giving here a try. :)
I have a 94 honda accord EX that recently entered the family (owned by girlfriend for about 4 years who then moved in with me so now it's my problem to fix <_< >_>) and they came from a state with no front plates.
Now i'm sure I can just get a cheap $8 front plate holder from Autozone but it only seems to fit with two of the four bolts into the non-flat-surface rounded plastic bumper and so I was wondering if that's strong enough to not fall off during the next 3mph fender bump in a parking lot. :- P I don't know if there is some kind of special bracket I should be using behind it, or if I should drill in two slightly smaller holes (than the bolts) into the bumper and assume it will be okay or what.. i'm a little leery drilling blindly into something too not knowing whats behind for that matter.
I'm just trying to minimize total expense as the car needs a bunch of other minor work and i'm not wanting to put much in until I see whether it makes it fine through the summer and some other postponed work that shoulda been done awhile ago. O_o
Old Jun 18, 2015 | 06:32 AM
Prospector's Avatar
Try looking at pay-&-pull junk yards in your area, a front plate mount should be priced fairly resonable there... or at a local Honda dealership
Old Jun 18, 2015 | 09:07 AM
I bought the 94 Accord, OEM part front plate mount from dealership. It is pretty pricey at $38 + shipping from Honda online parts. It did fit well, but only uses two upper side mounts.
Old Jun 18, 2015 | 06:40 PM
So it only uses two bolts anyways? Was there any special kind of bracket involved behind the bolts or is it pretty much drill then screw?
Old Jun 18, 2015 | 07:00 PM
The bracket bolts under the the bumper, so you don't have to drill. Look under the top part of the bumper and you will see two plastic tabs with a hole where a bolt/clip will attach. The bracket will bolt through the clips. It is very simple to install.
itmup44
Jun 8, 2014 11:14 AM
rgasman401
Jul 15, 2011 02:57 PM
H15A5H1
Jul 3, 2007 10:07 PM
jimbob312
Aug 30, 2006 02:26 PM
c0r5a38
Jul 13, 2006 12:42 AM
