94 Accord rear wheel alignment
Old Sep 9, 2007 | 01:33 PM
sedgerton
Default 94 Accord rear wheel alignment
My tire shop says I need aftermarket parts to enable full alignment of the rear wheels of my 94 Accord.
The dealer says this is isn't needed.
Who is right?
Old Sep 10, 2007 | 01:14 AM
deserthonda's Avatar
Default RE: 94 Accord rear wheel alignment
ORIGINAL: sedgerton
Who is right?
if you give us the alignment results we will let you know ,,
I cannot tell you who is correct without seeing the alignment readings , if they are out of specs or not ....
the only way either 1 would say that ,is if they put it on the alignment machine and saw the alignment readings ..
Old Sep 10, 2007 | 05:09 AM
ckebottle's Avatar
Just curious where you went? Pep Boys told my girlfriend she needed 100+ in repairs in order to align it right.....then she went to sears and they got it all to spec.
Old Sep 10, 2007 | 06:36 AM
My 94 Accord Shop Manual says only the toe-in can be adjusted. No caster or camber adjustment.
Old Sep 10, 2007 | 08:21 AM
ORIGINAL: TexasHonda
you are correct .......But if the camber is out of specs,( due to an accident ) some people opt to install a camber kit ( which can bring camber into specs thus no tire wear ) rather than replace suspension parts which can be more expensive ..
But i cannot give him the proper response till i see the alignment results
Old Sep 12, 2007 | 07:25 PM
sedgerton
The dealer did an alignment, and didn't say that anything is out of spec.
I'm a novice and don't really know how to read the alighment printout.
It gives Actual and Before values, so I assume the Actual are where they were after any adjustments. They are as follows:
Rear Left
Camber: -0.6
Toe: 0.08
Rear Right
Camber: -0.3
Toe: 0.09
Rear
Cross Camber: -0.3
Total Toe: 0.17
Thrust Angle: -0.01
loungewire
Oct 7, 2014 03:33 PM
lapper69
Sep 12, 2013 08:58 AM
creamystuffs
Oct 24, 2010 07:29 AM
Chaqui04
Aug 26, 2007 12:42 PM
deserthonda
Sep 29, 2006 01:52 AM
