94 Accord Shifter cable issue
Old Feb 21, 2021 | 02:35 AM
Skunx's Avatar
Default 94 Accord Shifter cable issue
Just swapped out my shifter cables on 94 accord wagon ex. 5 speed. But the cable that puts it into gear, it won’t compress enough to engage 2/4/reverse. It’s as if the cable is just a TAD bit too short. I bought the cables off eBay, listed as oem swap for 5th gen. Any ideas before I buy another replacement and then try to sell these ones since they ran me $270 🤦‍♂️
Old Feb 21, 2021 | 10:31 AM
Did the new cables have an OEM honda part number? The wagon might require a different part than the sedans. The easiest way to check is to go to hondapartsnow.com to see the OEM part number for a 94 ex sedan vs a 94 ex wagon. If the OEM part numbers are the same, you may have to do an adjustment on the cable.
You can do a google search for cd7-cd9.pdf and get a 94 accord shop manual pdf for free that will help describe the shift cable adjustment.
Drewbabich
Jun 12, 2019 11:15 AM
pr1madona
Feb 23, 2014 11:26 AM
Da Flash
Apr 28, 2011 08:07 PM
325wc
Nov 4, 2009 10:48 AM
toddyfresh
Aug 18, 2007 03:51 PM
