94 Accord Wagon California Emissions
Old Dec 15, 2012 | 06:22 PM
Dexity's Avatar
Default 94 Accord Wagon California Emissions
Okay so I bought a 94 wagon recently and I was under the influence that parts from my 97 would fit right onto it. So far, the rotors and breaks and distributor are different. Just one of the plugs are different on the distributor. Anyone here have any idea what else would be different on this car? I was hoping to just be able to pull parts off of one and put them on the other. Mostly the rack and pinion, as it is expensive!
Old Dec 16, 2012 | 09:08 AM
You've got a few things "in play" here.
First the 94 is OBD-I and the 97 is OBD-II.
Second could be the trim level.....vtec vs non vtec.
Something like the rack might swap over....look up the part number for both cars and see if they are the same.
Old Dec 16, 2012 | 09:36 AM
Roader's Avatar
Wagon front pads/rotors and rear wheel bearings are different and coupe/sedan parts won't fit. Rear strut assemblies will swap but the wagon's are heavier duty.
Old Dec 17, 2012 | 08:49 AM
Dexity's Avatar
It is non a non vtec LX. I was wondering if the brakes were because it is a wagon. I just broke down and bought a bunch of new parts! Anyone know where I can get a luggage rack that will go on the wagon easily? Ones that run length wise? That is something else I have been searching for, with little luck.
Old Dec 17, 2012 | 09:02 AM
Roader's Avatar
Try the for sale section at the AccordWagonClub(dot com).
daver1100
May 8, 2014 02:41 PM
gmike
Mar 19, 2014 12:45 PM
Ineedhelp
Jan 22, 2012 07:29 PM
chanonope
Aug 11, 2011 07:42 AM
retprep
May 12, 2011 10:03 AM
