94 Accord Wagon Tailgate Actuator!
Old Dec 28, 2014 | 06:11 PM
joe94wag's Avatar
Default 94 Accord Wagon Tailgate Actuator!
The actuator on my 94 accord wagon tailgate will no longer lock and unlock the tailgate. I can hear it clicking inside the actuator motor when the door lock button is operated, but it barely moves the tailgate lock button.
I opened up the actuator transmission, and the gears are turning very slow/weakly, and I think not in a complete cycle, so the pin which operates the lock and button is not being engaged.
Does anyone know about these, or know where I can get a replacement?
Many thanks...
Old Dec 28, 2014 | 06:43 PM
Tailgate door lock actuator is part of the tailgate latch assembly.
Honda part #74800-SV5-A01.
Old Dec 29, 2014 | 01:33 PM
joe94wag's Avatar
Thanks Redbull - and thanks so much for your help on that VSS issue.
Old Dec 29, 2014 | 04:42 PM
You're welcome.
Old Dec 30, 2014 | 09:49 AM
joe94wag's Avatar
Hey, I have another question: After I replaced the tranny and went to start the car, I got only a clicking sound. No starter engaged. I replaced the starter with a new one, and it did the same thing about five times and then cranked and started the engine. Since then it does it every time - I will turn key on and off about 5 or 6 times and it will eventually start. I purchased another negative battery cable, but haven't installed yet. Any guess as to what it might be, like a relay switch or something?
Thanks so much!
Old Dec 30, 2014 | 09:14 PM
Check that you have 12V going to the small blk/wht wire at the starter when you turn the key to the start position. If not, then you will have to work backwards. Is this a manual or automatic transmission vehicle?
Old Dec 31, 2014 | 11:13 AM
joe94wag's Avatar
Ok. It's an automatic.
joe94wag
Dec 28, 2014 06:36 AM
rriznyk
Nov 12, 2011 03:35 PM
rhinogolf
Dec 13, 2010 04:26 AM
jimcrosbie
Feb 17, 2009 09:02 AM
gaz238
Apr 17, 2007 08:08 PM
