94 accord will go in reverse sometimes but not into drive
Old Apr 9, 2020 | 05:04 AM
Vanessa Jenkins's Avatar
Default 94 accord will go in reverse sometimes but not into drive
94 will go in reverse sometimes and dr1 sometimes but no other gears
Old Apr 9, 2020 | 05:08 PM
Check for engine and transmission codes. The common diy thread on top of the gen tech help forum has a link to read CEL codes for your car. Post any codes on here
Did you check the transmission fluid level?
Any recent work done on your car?
Does the gear selector light in the cluster switch from P, to R, D4, etc. when you move the gear selector?
Old Apr 11, 2020 | 07:34 AM
I have checked the fluid its fine. The R,N, lights work but not all the drives lights work when shifted. I did have a gear shifter changed in my car the button to the shifter stayed pressed down for a cpl days before i realized that it was stuck down.... Thus it was pressed when i shifted in any gear. I also need cv axles someone told me they cld be popped out a little. Today i am checking all fuses and hopefully cleaning the solenoid
Old Apr 11, 2020 | 06:07 PM
The Toecutter's Avatar
Keep in mind you need a good bulb for the D4 position, as it's a sort of check transmission light for the AT, and is used for code reading. The other D- bulbs can be out, but that one (D4) does need to work.
david.fortune
Sep 5, 2011 09:16 AM
netlace
Mar 25, 2010 06:58 PM
Manpants
Apr 13, 2009 04:53 PM
naruto267
Jun 16, 2008 09:29 AM
laffinfish
Dec 27, 2006 06:12 PM
