94 auto 2.2, poor fuel milage! hard shifts?
Old May 4, 2013 | 05:20 PM
94accordtn's Avatar
Default 94 auto 2.2, poor fuel milage! hard shifts?
I have a 94 accord 2.2 automatic with 150k, I have been getting poor fuel mileage SO I changed the fuel filter, put new plugs, cap, but nothing has fixed it. The TPS went bad so I changed it, now I'm getting a CEL for tps and the d4 is flashing, also the car wouldn't start some times so I changed the engine control mod. But its still having spells where it won't firethe first couple of cranks......... Any advice or help ??
Old May 4, 2013 | 05:21 PM
94accordtn's Avatar
Also it has hard shifts and running 80mph its near 4000 Rpm's is that normal?
Old May 4, 2013 | 06:39 PM
Get the TCM code by jumping the service check connector and reading the flashes. See Diy forum for details.
Poor gas mileage usually results from aging o2 sensor which controls fuel/air mix. Other less likely causes are dragging brakes (lift and spin wheels to check).
Have you checked for fuel leaks at fuel injector/fuel rail connections. Corroded fuel lines are a possibility in areas where roads are salted.
Old May 7, 2013 | 01:25 AM
UhOh's Avatar
Originally Posted by 94accordtn
... and the d4 is flashing ...
No, too high rpm. I think your tranny isn't shifting into top gear lock-up.
Also, D4 flashing = check transmission indicator I believe.
BTW, when servicing your auto-tranny, the forum guru's here say to use only Honda brand AT fluid. luck
gdimattia
Nov 30, 2014 09:02 PM
Gopal
Nov 10, 2013 05:55 AM
vincentgould
May 20, 2011 12:17 PM
PJ_STYLES_95AccordEx
Nov 13, 2007 06:18 PM
zackp_99
Oct 24, 2007 05:24 PM
