94 lx coupe backfiring
Old Sep 5, 2009 | 12:53 AM
Mdschmidt's Avatar
Default 94 lx coupe backfiring
ok so when the car is cold its fine, but after i drive it for a while and warms up it would miss once and awhile and backfire that just started recently about 2 weeks after replacing the distributor... and when i drive the car and park it for a little but and get back it into drive i let off the clutch and it starts bucking and backfiring like im stoping without pushing the clutch in, it only does it for for a couple seconds then its fine... im thinking fuel filter cuz i just put a brand new fuel pump in so i dont know what else it could be any guesses?
Old Sep 5, 2009 | 09:08 AM
Sounds like an ignition issue; bad distributor cap, rotor, or wires that is allowing spark to short/jump to adjacent cylinders (backfire).
Old Sep 5, 2009 | 10:43 AM
Mdschmidt's Avatar
brand new cap and rotor with the new distributor and the wires arent very old just replaced them before winter along with the sparkplugs
Old Sep 6, 2009 | 01:37 PM
valerie's Avatar
You sure the wires are all connected right? Its common when replacing the dizzy that one wire may not clip in all the way.
Old Sep 9, 2009 | 06:07 PM
Mdschmidt's Avatar
yes i had the probelm with the bucking when starting out b4 i replaced the dizzy, but if i push the clutch in and rev it up when it starts to buck then try to pull out its fine. im using the OEM ngk wires and you can feel them clip in i used the repair book to make sure i had the right firing order too.
Josh Halse
May 17, 2014 09:21 PM
1999HondaAccordEXV6coupe
May 19, 2013 06:59 PM
Dualnames
Nov 1, 2012 07:05 PM
Stephenrod
Aug 25, 2010 01:12 PM
jamrock
Feb 11, 2009 08:58 PM
