94 speedometer not working
Old Oct 23, 2005 | 11:19 AM
cclc31
Default 94 speedometer not working
Hello to all. I saw a lot of people asking questions about the speedometer not working but I did not see any posted results. I changed my Variable Speed Sensor and it still does not work. Are there any solutions to this problem. Does any one have a real fix? I have guessed a few things but I would like to get it fixed so if you have any solutions please feel free to help me out. Thanks for your help.
Old Oct 23, 2005 | 10:08 PM
Evlampius's Avatar
Default RE: 94 speedometer not working
You told me that you replaced it at a dealer, however I wonder how did they apprehend it?? did they replaced the sensor because thats what you wanted them to do ? or They have diagnosed the problem and find out that VSS infact is faulty??
In any case - I would assume that even though it didnt work - they must have offered to diagnose the problem further.!?
Because you checked the connecters and they all pluged proper, I would lean toward an open wire somewhere (like a loose connection) or the other possibility is Faulty ECU , however these are just assumptions - Unfortunately, more diagnostics are needed inorder to find out the problem.
Old Oct 25, 2005 | 05:18 PM
cclc31
When the problem came up, I took the car to the dealer and was told by the dealer that it was the VSS. I purchased the VSS from a dealership in California and has it installed in the dealership in Germany where I am stationed at. When I gave them the VSS and had it changed out it still did not work and now they are telling me that it is the speedometer which cost around $300. This is why I asked if anyone had any results on the repair of the speedometer. Thanks for you quick response and your advice. Thanks
Old Oct 25, 2005 | 09:27 PM
Evlampius's Avatar
It is very sad that even in Germany people are getting screwed by the dealerships [:'(]
There is very simple procedure to test the speed sensor - and it has to be executed before replacing the VSS.
That is why we charge $65 diagnostic fee - without making customer buying unnececary parts.
Check the ground G101 - it is located to the left of the master cylinder - this ground grounds the VSS. Clean it - regrease it and see if it works.
If you a little proficient with diagnostics - heres how to run a quick test on VSS :
1. Check the fuse #1. (10A)
2. Disconnect the 3 pin connector from VSS
3. turn the ignition switch ON
4. If you look inside the connector with the clamp being on top - the wires in side ORANGE - BLACK - YELLOW
* Check black to continuity to the ground - there should be continuity
* check Yellow wire for voltage to the ground - there should voltage
* check Orange wire for voltage to the ground - there should be about 5 Volts.
And check for voltage between Yellow terminal and Black terminal - is there a voltage (ignition Switch ON)
if you get to this point we might diagnose further....
Certain check up procedures are to be made before replacing the speedometer - The speeedometer part is not repairable thus needs to be replaced as whole - $300 is about right price off a dealer -
Just if you decide to replace it - make an arrangment that you will only agree to pay the price if it fixes the problem.
...And that is pretty much all what i can help you with here. (More actual diagnostics needed)
good luck! Aufiderzein!
forestcd6
Jan 10, 2018 12:42 PM
hffej54
Mar 14, 2009 06:36 PM
1joker069
Feb 12, 2009 03:16 PM
accordEX99
Nov 3, 2008 02:22 AM
sebastian
Jan 9, 2008 12:10 AM
