95 Accord 2.2 auto trans issues.....
Old Jun 4, 2010 | 07:16 AM
Bades's Avatar
Default 95 Accord 2.2 auto trans issues.....
ALrighty guys long story short I have this 95 Accord with an Auto trans f22b.... well i did a complete swap with all the stock components bc my vehicle had 200000 miles.... well about 2 weeks after the swap i noticed that when the vehicle had been driven for around 20 mins the trans would no longer downshift when u mashed on throttle... i could manually select the gear and it would do fine.. in addition the vehicle when starting from a dead stop would shift at 3000 rpms for ever gear no matter what..... but when u just put the car in neutral while driving and shut the power off and start it back up the issue would go away for another 20 mins or so....
I have checked the trans codes and i only get a code when the vehicle is on and has just stated acting up....the code i pull is code 3.... i hear from sum ppl that code3 is MAP sensor issue... others say its the TPS..... any help on this matter would make my life much easier as I and my friends are all stumped...
Old Jun 4, 2010 | 11:34 AM
Which light flashed the code 3, the check engine light or the D4 light?
Old Jun 4, 2010 | 02:10 PM
Bades's Avatar
the d4 light... i may have figured it out... i just swapped the ecm and for sum reason it hasnt acted up yet....
2003AccordEX
Dec 5, 2012 11:47 AM
hajoto36
Oct 2, 2012 11:12 AM
chastings
Jan 2, 2012 10:13 PM
902drdx
Dec 13, 2010 09:50 AM
cecoen
Sep 3, 2009 03:58 PM
