95 Accord DX no headlights or turn signals
Old Jun 10, 2014 | 07:24 PM
the 18th letter's Avatar
Default 95 Accord DX no headlights or turn signals
I got the car back from the police after it was recovered, theft, and replaced the ignition. Now I have no headlights or turn signals. I still have parking lights and dash lights tho. I checked the brakes lights which are fine, as well as reverse lights. Unable to check the hazard lights because the console is missing from where the radio was stolen and I don't have a button. Any suggestions?
Old Jun 11, 2014 | 12:01 AM
You need the hazard switch installed to have the turn signals working. All the wiring goes through that switch.
As for the headlights, start by checking the fuses. Do the headlights work?
Old Jun 11, 2014 | 10:13 AM
As i stated before the headlights don not come on. They worked prior to the theft. There is a connector on the column for the headlights which I cleaned to see if that was problem but no go. The only thing that will come on is the parking lights and the lights on the dashboard. I mean have to get another console so I guess the hazard switch would be a good place to start. Additionally all the fuses associated with the headlights and turn signals are intact.
Old Jun 11, 2014 | 11:57 AM
Good call on the hazard switch, I have signal lights now, but still no headlights. I had the connector to the headlight tested and there's no power to the headlights. Fuses all seem fine. Gonna check now and make sure I'm checking the right fuse.
Old Jun 11, 2014 | 03:42 PM
The fuses were fine, but the lighting relay was missing. I hate thieves... At least my son is now back on the road. I bet he won't leave the club in the trunk the next time he parks it. Not that it's invincible but you gotta give some resistance, low lying fruit is easy pickings.
Old Jun 11, 2014 | 11:02 PM
I meant to ask if the high beams worked before.
Anyway, thanks for posting the solution.
hypologix
Oct 2, 2010 12:21 AM
twisted95accord
Sep 4, 2010 09:10 PM
kennyxu
Sep 24, 2009 10:01 PM
Shandy.Trekell
Oct 1, 2008 12:52 PM
Mzanuel513
Nov 15, 2007 05:14 PM
