95 accord.....electric issue
Hi....my names Walt and I have a '95 accord(automatic). The other night I was driving home and on a curve my cluster lost power for a second. All the gauges dropped to zero and then came back up. It was fine for the rest of the drive home and back to work (40 mile trek). The next night at the same curve it happened again but this time it kept doin it until it just finally cut out for good. The lights would dim and the gauges would drop to zero. Now it will turn over and wants to start but won't stay started. I noticed last night that to roll the window up I had to turn the key to the start position. I'm thinking ignition but wanted to verify with you smart fellas....once again it's a 1995 accord with VTEC 4 cylinder automatic
Welcome to HAF.
If you have a volt meter there are a few tests we can wlak you thru to confirm the switch.....like, the key to on/Pos II. Check for voltage on the BLK/YEL at the dist? What do you have........
nickvilardi
Aug 15, 2011 12:18 AM
LambertJohn
Sep 17, 2010 01:47 PM
